i need to evaluate the flare stack performance
i have some questions regarding this flare rating :
a. Flare Mach Number :
as per API RP 521, mach number in flare tip shall be 0,5 at emergency scenario. based on the condition at 65 MMSCFD, the mach number is 0,7 for the existing diameter of flare. what will happen if the mach number is 0,7 ? what is the negative effect ?
b. Flare Velocity :
according to API RP 521, there is phenomenon called blowoff (high flare velocity) or flashback (low flare tip velocity). since there is increasement in flowrate ( up to 65 MMSCFD), blowoff may happen in the flare stack. the problem is... i can't find the velicity limit to avoid blowoff (or flashback) in API RP 521
could you please point me out in what paragraph that this limit available in API RP 521 ? (or other references)
c. Noise Limit
due to higher velocity, excessive noise may become a problem, again, i can't find the noise limit for flare in API RP 521. could you please point me out in what paragraph that this limit available in API RP 521 ? (or other references)
d. additional flare
is it ok to just add another flare in a flare system network
My reference : API RP 521, 1997 edition.
thanks in advance, i really need your help.
