With reference to the above posts regarding API standard 2000. I have a copy of the fifth edition printed in april 1998. Regarding the expression given for venting requirements in metric units, I think that the latent heat should be expressed as J/kg not kJ/kg...anyone disagree?
Api 2000
Started by niallmacdowell, May 08 2006 07:12 AM
Posted 08 May 2006 - 07:12 AM
Posted 29 January 2007 - 03:15 AM
QUOTE (niallmacdowell @ May 8 2006, 07:12 AM) <{POST_SNAPBACK}>
Dear niallmacdowell,
I am in agreement with you if you refer to API 2000, 5th ed., Apr. 1998, page 8. The latent heat should be J/kg.
In addition, the Wetted Surface Area, section 4.3.3.2.1, under SI unit table, it should be "(square meter)" instead of "(square mm").
Hope you agree with me.
Best regards,
JoeWong
Posted 31 January 2007 - 09:58 AM
In Nov. 1999, API published an errata for formula 1B, page 8 as well as formula 5B, page 20 stating the units on "L" to be J/Kg.
Determining The F-Factor Following The Api 2000Started by Guest_Hachimi_* , 06 Sep 2024 |
Api 2000Started by Guest_Lucianaa_* , 04 Jan 2024 |
Nitrogen, Api 2000 Section 3 Vs Annex FStarted by Guest_Rmm27_* , 23 May 2022 |
Api-2000- Thermal Inbreathing Due To Variation In Rain IntensityStarted by Guest_aju_1807_* , 03 Aug 2021 |
Api 2000 - Annex FStarted by Guest_Raj Mehta_* , 13 Aug 2018 |
