Cryogenic Argon Cylinder Filling
Posted 25 September 2015 - 06:32 PM
Please give me valuable suggestion to me
Posted 26 September 2015 - 02:31 AM
Question framing seems odd.It lacks clarity.
What is the supposed suction pressure at pump inlet? Is it 0.65bar(g)
But level 40 or 50 percentage we couldn't start the pump because of pressure is 0.65 bar we could not raised the pressure because of we are getting production online. At the same level pressure increased means pump getting load but production we are not taken that time.
I can't fathom what u say in the above statement.
Please clarify
Bodhisatya
Posted 26 September 2015 - 02:55 AM
Posted 26 September 2015 - 07:44 AM
What is the Pure Argon Column pressure?
When the level is around 80 % , what is the dP between PAr and Argon storage tank.
When the level goes down,maintain that same dP using a Pressure building coil;as the pressure begins to fall.
Please confirm whether u have a PB coil attached to your tank ?
Bodhisatya
Posted 17 November 2015 - 12:43 AM
Did you ask the pump supplier for Min require NPSH & NPSP ??
Does piping as per Pump Manufacturer recommendations !!
If it is operating at 80% Level and above than I assume that it is a problem of NPSH ...
Posted 17 November 2015 - 02:51 AM
Dear,
1 If this is the cryogenic pump you must have sufficient cooling of pump casing & have proper venting line from the casing. Because this type of pump is cavitating very fast. Pl confirm that you don't have any vapor pocket in pump casing & It will always filled with liquid.
2 As per Mr Vikas Patel said NPSH problem for suction is also possible.
3 Keep above 80% level & filling cylinder until other solution is found.
4 Check suction strainer / Mesh size.
Manoj
Cryogenic Distillation To Produce Nitrogen GasStarted by Guest_Eng4324_* , 04 Mar 2024 |
Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
Converging Cryogenic Air Separation In HysysStarted by Guest_rgc1994_* , 22 Mar 2017 |
Cryogenic Separation Of Steam Reforming SyngasStarted by Guest_Fjm989898_* , 15 May 2023 |
Cryogenic Distillation For Oxygen And NitrogenStarted by Guest_xyadap_* , 23 Mar 2023 |
