Thermic Fluid Flowrate Required To Heat Hydrocarbon Mass From 150 Deg
#1 sunil bendi
sunil bendi
  • 5 posts
Posted 15 October 2015 - 02:18 AM
How to calculate thermic fluid flow rate ,ie heating hydrocarbon fluid from 150 to 210 deg c in pre heater .
Actually i want to give specification to vendor for a control valve .
control valve is in thermic fluid line ie going to preheater where hydrocarbon is heating from 150 to 210 deg c using thermic fluid .
what data required and how flow rate of thermic fluid is caluculated for required heating of hydrocarbon from 150 to 210 deg c
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 15 October 2015 - 02:44 AM   Best Answer
sunil,
This is a simple heat balance calculation (Q= m*Cp*deltaT). However, a lot of data is missing from your side. Some of the data required is:
1. Mass flow of hydrocarbon
2. Avg specific heat of hydrocarbon @ ((150+210) / 2) deg C
3. Supply temperature of thermic fluid
4. Return temperature of thermic fluid
5. Specific heat of thermic fluid @arithmetic avg of supply / return temperature
Once you have all this data, the heat balance equation will give you the mass flow of thermic fluid.
#3 sunil bendi
sunil bendi
  • 5 posts
Posted 16 October 2015 - 03:44 AM
Thank you sir
1. Mass flow of hydrocarbon   --   6400 kg /hr
2. Avg specific heat of hydrocarbon @ ((150+210) / 2) deg C -- 0.42 kcal/kg 0c
3. Supply temperature of thermic fluid-- 282   0c
4. Return temperature of thermic fluid ---  272   0c
5. Specific heat of thermic fluid @arithmetic avg of supply / return temperature --  0.71  kcal/kg  0c
i caluculated i got  thermic fluid flow rate as 39 m3/hr.
But i guessed density of servotherm super oil  , i didnt got real value from data
Thanks sir
#4 breizh
  • 6,353 posts
Posted 16 October 2015 - 11:31 PM
Another brand which is close to your working condition . You may compare the data on your hands with those I attached .
#5 sunil bendi
sunil bendi
  • 5 posts
Posted 23 October 2015 - 06:29 AM
thank u sir
