Would appreciate if someone could give me an insight on how to re-characterize fluid to match HYSYS predicted viscosity with lab results. Challenge : Density should remain the same, only pseudo-component details are available.
Re-Characterization Of Fluid To Match Actual Viscosity
Started by rizwanmah, Nov 04 2015 09:40 AM
re-characterization hysys
No replies to this topic
Posted 04 November 2015 - 09:40 AM
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
Excel Based Calculator For Fluid Bed DryersStarted by Guest_outcast_* , 15 Mar 2023 |
Low Velocity Problem Of Fluid In Hairpin Heat ExchangersStarted by Guest_AnbIran_* , 16 Jan 2023 |
Temperature Rise Of Fluid Due To Friction Of The PipeStarted by Guest_panagiotis_* , 17 Dec 2022 |
