Difference Between Wet And Dry Flare
flare types
#1 NewUser101
NewUser101
Posted 17 November 2015 - 10:08 AM
I am new process engineers and really confused about the terminology of Wet and Dry flare.
What exactly is the fundamental difference between these two and what is the application?
I looked online to find some quick articles but some how i could not find well written article or explanation.
I will also appreciate If you can point me to a good article or a starting point.
Thank you for your help!
#2 fallah
  • 5,026 posts
Posted 17 November 2015 - 11:12 AM
Difference in brief:
A wet flare header is usually used to handle flare gases that contain moisture but aren't cold gases...
A dry flare header is usually designed to handle dry flare gases which also are cold (below around -46C)...
#3 shan
shan
  • 692 posts
Posted 18 November 2015 - 11:44 AM
To me, a wet flare is a flare with steam/water injection while dry flare without steam/water injection.
#4 Alexsandres
Alexsandres
  • 27 posts
Posted 14 December 2015 - 09:23 PM   Best Answer
Fluids containing wet hydrocarbons, such as disposal from offshore receiving facility, acid gas removal, dehydration/mercury removal, debutanizer and condensate stabilizer is disposed to wet flare.
While dry flare system will handle liquid and vapour discharges from sources that contain no water or CO2 to avoid freezing in the flare system. Usually this stream comes from refrigeration unit, fractionation unit, gas liquefaction.
This link can be useful
http://www.hydrocarb...se-history.html
A wet flare header is used to handle flare gases that contain moisture but are not “cold” gases.
• An intermediate flare header, which could contain some moisture and normally handles some cold vapors (up to –45°C).
• A dry flare header designed to handle dry flare gases. These will also be cold, with normal temperatures below –45°C.
#5 NewUser101
NewUser101
Posted 16 December 2015 - 10:12 AM
Thank you all for your reply.
