Edited by lballantine833, 23 November 2015 - 03:18 AM.
Posted 20 November 2015 - 06:04 AM
Posted 20 November 2015 - 07:32 AM
It is a typical blowdown case. You may use a dynamic simulation model to figure out your peak flow and valve size based the blowdown time and final pressure requirement.
Posted 20 November 2015 - 10:21 AM
simulators solve these problems by subdividing the whole cycle in n steps, solving each step and then integrate (in some cases adopting a simplified model),
you can follow a similar method (by hand or with the help of Excel, Matlab or Mathcad to mention a few tools) or use a simulator as suggested by shan.
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
Back Pressure Of Elevated Flare Vs Ground FlareStarted by Guest_Sid__* , 04 Jan 2024 |
