Design Pressure And Temperature Of Plate And Frame Heat Exchangers
Posted 04 April 2016 - 06:00 AM
In a finished project, the vendor of plate and frames has chosen a unique design pressure and temperature and accordingly a unique hydrotest pressure for both hot and cold sides. In other words vendor has chosen the highest design pressure of either hot or cold sides and highest design temperature of either hot or cold sides for both. Does anyone know something about it? Is it a common practice to consider an identical design pressure and temperature for both sides?
Posted 04 April 2016 - 06:48 AM
Hi Ali,
For plate and frame heat exchangers, there should be separate Design Pressure/Design Temperature values for Hot/Cold sides hence separate Hyrotest pressure values for mentioned sides.
Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 21 May 2026 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
