Currently, Column bottom line is connected with heat exchanger shell side top nozzle , then, heat exchanger shell side bottom outlet is connected with pump suction. Due to the routine through heat exchanger to pump, high pocket is inevitable. The problem is the elevation of highest pipe between column bottom and heat exchanger shell inlet. The elevation of highest pipe is higher than column bottom low level. If column level control is failed, high cavitation could happen at heat exchanger inlet.
Heat exchanger will cool down shell side fluid.
I'm wondering if column bottom fluid is enough subcooled through heat exchanger, generated cavities could disappear.
Please share anyinformation regarding pump suction high pocket and cooling.
