Indirect Type Heater Calculations
Posted 30 May 2016 - 08:01 PM
Posted 30 May 2016 - 08:50 PM
FedericoFE
In my experience, viscosity of crude oil shall be obtained from experiment.
If you are EPC engineer, you should ask client about viscosity of crude oil.
In simulation, viscosity of crude oil cannot be calculated exactly and water and oil are not mixed.
Posted 30 May 2016 - 10:45 PM
I would think that the suppliers of such equipment have a method. Since this operation is quite common. HTRI probably has a method that they use, too. Are you really designing this for fabrication?
Posted 03 June 2016 - 06:04 AM
Dear Fed..
May I suggest that you use water viscosity since the composition is 90% and the the viscosity of water is larger than crude oil that shall give lower heat transfer coefficient so the size required is bigger. Slightly bigger exchanger is good from operational perspective but not investment point of view. The project manager shall be unhappy but the operator shall be the most happier.
Would you please check he size if you are using the oil viscosity. I believe the difference is marginally acceptable and reasonable.
S.ahmad
Agitator CalculationsStarted by Guest_Biomass Process_* , 04 Jun 2026 |
Choosing The Right Type Of Evaporator For Removing Hcl From Aqueous SoStarted by Guest_anggara_* , 09 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
