Thanks so much for your help, Sir
Edited by Hoang Nguyen, 14 June 2016 - 01:59 AM.
Posted 08 June 2016 - 09:39 PM
Posted 09 June 2016 - 11:36 PM
In my experience, it took 7 days to start CDU. First, cold circulation for 3~4 days ,then, hot circulation for 3~4 days ,then, load up slowly.
To live CCR and BTX , it took almost one month. When you heat up big column, take care of thermal expansion.
Unfortunately, I don't have documents show detail.
Edited by S J, 09 June 2016 - 11:36 PM.
Posted 13 June 2016 - 09:26 AM
Hi Hoang Nguyen
For your help.
Has your refinery operation manuals to review?
How about records of your refinery startups?
And the technical documentation for consult about this issue.
You need specifically the operation manuals for each units and review and studied it carefully.
You need a technical advisor for this job if your refinery has not experience in complex refinery start ups. This is the cheapest solution. if you think about HSE.
I think this little bit will be useful.
Fausto
Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
Logic For Start Up And Shutdown Of Hp CompressorStarted by Guest_umeshgps_* , 17 Aug 2024 |
Start New Topic ButtonStarted by Guest_latexman_* , 20 Apr 2024 |
Literature To Read For Refinery Oil MovementStarted by Guest_Noman97_* , 09 Nov 2023 |
