Dear
For AES type (R-Class) S&T heat exchanger, how to calculate velocity at the inlet of the shell nozzle? and is there any standard for maximum velocity in the shell side and tube side to maintain?
Thank you,
Sameer
Posted 06 February 2017 - 07:44 AM
Dear
Thank you,
Sameer
Posted 06 February 2017 - 12:36 PM
You can find equations at www.gulleyassociates in the engineering tips section. Look for "Calculate shell nozzle pressure drop". It will give you equations for the shell entrance or exit area. From this you can calculate the velocity at the inlet of the shell nozzle.
For maximum velocities you can search this website for answers.
Posted 07 February 2017 - 11:15 PM
Dear Sir,
Thank you so much and indeed it is very helpful website.
Thank you
Best Regards,
Sameer
Electric Heat Tracing—Pipe-Wall Temperature Vs. Actual Fluid TemperatuStarted by Guest_zamakaze_* , 20 Sep 2026 |
Installation Of Vertical Pass Partition Plate In Kettle Type Steam RebStarted by Guest_jigs1980_* , 09 Sep 2026 |
Screening Heat & Material Balances Cases For Fire Relief Psv SizinStarted by Guest_powerox6_* , 21 Aug 2026 |
Nitrogen Flow Meter Dp Type ErrorStarted by Guest_Ranga v_* , 18 Jun 2026 |
