Dear all,
When sizing a centrifugal pump for a particular system, I was wondering what happens when you overestimate your system losses. So for example: I wish a cooling water flow rate of 50 m3/h delivered by the pump and I calculated the system losses (pipe, fittings, valves, static head, heat exchanger, ...) to be 3,5 barg.
Suppose I have to install this new pump in an already operational cooling water system that needed a new pump because the previous flow rate was too high. What happens now because I overestimated the system losses, what will happen to my pump? Is the only consequence that it will deliver a higher flow rate (following the pump curve) because the system losses in reality are less then my design? What can I do about it to adjust it to the required flow rate? Install a restriction orifice?
Thanks!
