Is there a requirement from API to have the isolation valve to be interlocked instead of just locking device if the upstream design pressure is very much higher than the downstream pressure?
For example upstream is 1500# and downstream is 300#. Downstream relief system is protected against blowby from the upstream system.
Interlock
Started by janson_kaniaz, May 17 2017 05:53 PM
Low Rot Interlock In FccuStarted by Guest_SANDEEPCH_* , 05 Jun 2018 |
Gas To Air Ratio Interlock In Ammonia PlantStarted by Guest_Riaz01_* , 13 Oct 2017 |
InterlockStarted by Guest_janson_kaniaz_* , 09 May 2017 |
Key Interlock SystemStarted by Guest_m42364236k_* , 04 Nov 2014 |
Logic Behind Interlock / TripStarted by Guest_ankur2061_* , 07 May 2014 |
