Heat Transfer Through Tank Roof
heat transfer
#1 August
August
  • 38 posts
Posted 21 June 2017 - 03:14 AM
There is a rectangular water container.
wall and bottom is insulated with some polyester material.
roof is covered with stainless steel cover no insulation. roof is 12 m2.
Water in tank is 60C. Amb temperature is -30C. height of tank is 2m. water level is 1.5 m.
I am calculating the heat loss through the roof cover.
But it comes up with super huge value, if I apply the condutive heat transfer fomular.
q=k.A.dT/s
Should I consider the 0.5m vapour as insulation layer?
  • 6,349 posts
Posted 21 June 2017 - 04:15 AM
Consider the resource attached to support your work .
Yes the vapor space will play a role in heat transfer .
Hope this helps
#3 August
August
  • 38 posts
Posted 21 June 2017 - 06:10 AM
Thanks Breizh. That's very helpful.
#4 ElSid
ElSid
  • 31 posts
Posted 17 April 2018 - 01:21 PM
Revised article by Art here https://www.cheresou...+heat +transfer
