According to counter current temperature gradient diagram of Heat Exchanger, we will find that the inlet temperature of the cold stream always smaller than outlet temperature of the hot stream in the right side of the diagram.
as you know counter current is preferred because cold stream outlet temperature will be higher than hot stream outlet temperature so maximum heat is extracted from hot stream .
my inquiry is about if i raised the inlet temperature of cold stream to be higher than outlet temperature of hot stream exactly to locate the temperature in between the range was gained before raining inlet cold stream temperature??
for example ... if we have cold stream (water) that is temperature will increase from 20 to 100 C, so i can reduce temperature of hot stream (crude oil) to 90 C ..... if i use water with 92 C upraising it to 100 C, why not intersection between two lines in diagram happens, and I get the same result as before 90 C (crude oil), that doesn't happen?
Please explain!
