I would like a help a project of retrofitting a column used as a stripping tower to a ammonia vapor absorber (for the production of aqua ammonia solution).
Although I have in mind that there are alternative designs possible, I focus on a two-bed packed tower design.
Based on my rating calculations the column diameter is 4-5 larger than that required for the gas capacity (approx. 20-30% of Maximum Operating Capacity). Moreover at the top of the bed the gas velocity will be very low.
My questions are:
What will be the effect on process efficiency?
What should be done to have a stable and efficient operation of the column (e.g. Suitable Packing)
