does anyone know where can i find Lead sulfate solubility vs pH chart?
Posted 16 October 2017 - 06:24 AM
Posted 16 October 2017 - 06:54 PM
Probably there is no chart for this. Because it depends on how you vary the pH.
You have to solve the simultaneous equations of the Solubility Product, the water dissociation and (if you are using a weak acid or base) the dissociation of that acid/base
Say, for example, that you increase the pH using sodium hydroxide. You will end with a solution of sodium sulfate and lead hydroxide. So...what "solubility" means here?
If you decrease the pH using sulfuric acid, you have the common ion effect. If you use nitric acid to lower the pH you may get differnt result.
Hysys Convergence Issue Related To Ammonium SulfateStarted by Guest_Victfmanzana_* , 27 Jun 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Simulating Solubility Of Ammonia Gas In WaterStarted by Guest_abdullahq7_* , 30 Jan 2024 |
Quaternary System Solubility (Nacl-Mgcl2-Kcl-H2O) (Nacl Solution MininStarted by Guest_jordan1111_* , 10 Jun 2022 |
Relation Of Solubility And Vle (Equilibrium)Started by Guest_qhsuoo_* , 09 Jul 2021 |
