Psv Nozzle
10 replies to this topic
#1 Kachisa
Kachisa
  • 77 posts
Posted 14 November 2017 - 10:18 AM
Hi All,
I got a mach number at PSV outlet nozzle  = 1 but 0,7 at pipe outlet.
It is ok ?
Thank you
#2 Bobby Strain
Posted 14 November 2017 - 11:53 AM
We have no idea what you are doing. Maybe you can provide some information so we might help.
#3 Kachisa
Kachisa
  • 77 posts
Posted 14 November 2017 - 12:08 PM
Dear Mr. Bobby,
API recommend to limit mach number of pipe oulet to 0,7 but it does not talk about PSV outlet nozzle.
I am checking an existing PSV, and I got a Mach Number at PSV outlet nozzle = 1.
#4 fallah
  • 4,955 posts
Posted 14 November 2017 - 12:41 PM
It is ok ?
Kachisa,
It could be possible in critical flow through the PSV means having sonic flow in PSV orifice which will result in a subsonic flow through the relevant tail pipe due to the back pressure...
#5 Kachisa
Kachisa
  • 77 posts
Posted 14 November 2017 - 12:47 PM
Thanks Mr. Fallah for your comment.
I got clearly your idea and I totally agree with you.
My worry is not the result, it is rather sound criteria.
Another point : the PSV is sized only for fire case.
As fire flowrate is very important, I will use 2 PSV.
My question is : if these PSV should be staggered ?
I see that is not necessary.
#6 fallah
  • 4,955 posts
Posted 14 November 2017 - 12:53 PM
If you have to use multiple PSV's to handle the whole relif load they should be staggered.either in fire case or in another case...
#7 Kachisa
Kachisa
  • 77 posts
Posted 14 November 2017 - 01:01 PM
Thanks Mr. Fallah,
2 PSV in service : 1 PSV * 100% + 1 PSV * 105 %
How about the spare PSV, it is set at 100% or 105%, and why ?
#8 fallah
  • 4,955 posts
Posted 14 November 2017 - 01:11 PM
Spare PSV should be set same as the main PSV...because it's not intended to be operated simultaneous with the main PSV ..
#9 Kachisa
Kachisa
  • 77 posts
Posted 14 November 2017 - 02:48 PM
Thank you Mr. Fallah,
But PSV 105% may fail ? It is a recommendation from API ?
#10 fallah
  • 4,955 posts
Posted 15 November 2017 - 01:27 AM
Your statement isn't clear; please explain...
#11 demank
demank
  • 149 posts
Posted 15 November 2017 - 09:25 AM
For Fire Case PSV, it is not necessary to install spare PSV.
