Purge For Burn Pit Flare
flare purge
6 replies to this topic
#1 Sue N
Sue N
  • 19 posts
Posted 06 December 2017 - 02:23 PM
One of our older plants has a burn pit ground flare, and we are trying to validate the purge rate for it.
How does one calculate a purge rate for a flare with this configuration?  API521 6th Edition has guidelines for purging the stack, but a burn pit doesn't have a stack - it is just an open pit.  The equations in  API521 (46 & 47) reference a variable "y" called "column depth at which the O2 concentration is predicted".   In the case of a burn pit, would "y" be the depth of the pit, the height of the pilot tip, or some other value?
Eqns 46 & 47 also reference a variable "D", the flare stack diameter.  In the case of the burn pit, would this be the flare header diameter?
Are there different methods in another reference or standard that I should use instead?
Thank you in advance for your help.
Are there different equations in another reference or standard that I should use instead?  If the API calculations are appropriate, what would I base the value of "y" on - the depth of the pit, the height of the pilot tip, or something else?
#2 fallah
  • 4,954 posts
Posted 07 December 2017 - 06:13 AM
Sue N,
Do you think a liquid burning system has to be purged during operation like a gas burning flare?
#3 Sue N
Sue N
  • 19 posts
Posted 07 December 2017 - 10:02 AM
The flare is for a gas plant, so it isn't really a liquid burning flare.  I think a way to describe it is like a horizontal flare stack that exits into a pit.
#4 fallah
  • 4,954 posts
Posted 07 December 2017 - 10:48 AM
Might you mean a ground flare?
#5 Sue N
Sue N
  • 19 posts
Posted 07 December 2017 - 11:01 AM
I don't know the exact manufacturer, but this Zeeco link has something that looks like the burn pit.
https://www.zeeco.co...nd-burn-pit.php
#6 Sue N
Sue N
  • 19 posts
Posted 07 December 2017 - 11:05 AM
I apologize for my lack of knowledge and my trouble describing the system.  Most of the plants I work with have elevated flares.
#7 Bobby Strain
Posted 07 December 2017 - 11:35 AM
I would contact Zeeco for help.
