Heat Balance For A Steam Reformer Unit
264 replies to this topic
#126 PingPong
PingPong
  • 1,474 posts
Posted 18 February 2018 - 11:14 AM
So the edited value of 203.0289 kW for the steam in the process is correct then..... is it ?
Yes and No.
Remember that you will not mix all HPS with the gas feed.
How do we move further once the BL conditions are known ?
See my message #121.
Why do we find the enthalpy of steam at 25°C and ideal gas state ?
For the same reason you calculated (in your spreadsheet) all gas enthalpies relative to IG@25C before. I explained that weeks ago.
#127 ravindra@096
ravindra@096
  • 41 posts
Posted 19 February 2018 - 11:16 AM
The battery limit conditions specify the temperature of natural gas at B.L is 40 degrees Celsius and the pressure is 36 bara.
The natural gas and H2 mixture temperature is calculated by the formula m.Cp.(100-T) = m.Cp.(T-40) ,T being the temperature of the mixture. The mixture is assumed to behave ideally.
Cp values are calculated at respective temperatures of 100 and 40 degrees Celsius for H2 and natural gas. Natural gas mixture Cp is calculated by adding the product of mole fraction of constituent gases and their Cp at the given temperature.
The temperature of the mixture of recycle Hat 100 degrees Celsius and natural gas at 40 degrees Celsius is calculated as 42.2384 degrees Celsius.Please have a look at the attached thumbnail.
How do we preheat the mixture of natural gas and H2 to the specified HDS inlet temperature ?
#128 PingPong
PingPong
  • 1,474 posts
Posted 19 February 2018 - 02:08 PM
That is the amateur way to estimate the mixture temperature.
More professional is to calculate the enthalpy of both gases, add them together, and determine what temperature of the mixed gases gives the same enthalpy. Similar sort of calculation as was used to determine WGSR inlet temperature.
That is for you to determine later.
But first you need to determine how much preheat duty is needed.
#129 ravindra@096
ravindra@096
  • 41 posts
Posted 20 February 2018 - 06:20 AM
The temperature of the mixture of natural gas at 40 degrees Celsius and H2 at 100 degrees Celsius comes out to be 42.24639 degrees Celsius using enthalpy difference method.
The natural gas preheat duty comes out to be 89.03128805 kW (92.69120381 - 3.659915768).
Now what I reckon is the mixture after passing through HDS and ZnO bed moves to the convection section of the  reformer furnace to achieve the XOT of 550 degrees Celsius which is the reformer inlet temperature.
#130 PingPong
PingPong
  • 1,474 posts
Posted 20 February 2018 - 08:10 AM
89 kW to preheat up to 370 oC is correct.
But that is only part of the total required preheat, you still need to calculate the part from ZnO to XOT.
#131 ravindra@096
ravindra@096
  • 41 posts
Posted 20 February 2018 - 08:26 AM
The enthalpy of mixture at 370 degrees Celsius is 92.69120381 kW and at 550 degrees Celsius is 155.6321235 kW their difference being 62.94091969 kW. That means we need total 152 kW (89 + 63) in order to preheat the mixture from the 42.2463 degrees Celsius to XOT of 550 degrees Celsius.
#132 PingPong
PingPong
  • 1,474 posts
Posted 20 February 2018 - 08:52 AM
That is not correct.
I suggest you read my messages on page 5 once more.
#133 ravindra@096
ravindra@096
  • 41 posts
Posted 20 February 2018 - 09:09 AM
The ZnO bed effluent at 370 degrees Celsius is mixed with the required amount (61.47 kmol/hr) superheated steam at 385 degrees Celsius and the mixture (whatever the mixture temperature is) is again heated to XOT of 550 Degrees Celsius. It is the mixture of process steam and natural gas which has to be heated to XOT and not the natural gas (mixed with recycle H2) alone.
Is any temperature drop across the HDS and ZnO bed required to be taken into account or the temperature be taken as 370 degrees Celsius at the ZnO bed outlet ?
#134 PingPong
PingPong
  • 1,474 posts
Posted 20 February 2018 - 09:45 AM
If everything were perfectly heat insulated there will be no temperature change over HDS & ZnO as there is in this case no enthalpy of reaction.
In reality however all piping and equipment will loose some heat. That is not only the case for the HDS & ZnO but also for the WHB, the WGSR and all other equipment and piping. Also the radiant and convection sections of the furnace loose some heat. Moreover there is a small leakage of cold ambient air into the furnace that affects the real flue gas temperature.
For the moment I suggest you neglect all that. You can try to estimate that later when finalizing the process scheme and heat balance.
#135 ravindra@096
ravindra@096
  • 41 posts
Posted 20 February 2018 - 09:58 AM
The enthalpy of Natural gas at 370 degrees Celsius is 92.69120381 kW and the enthalpy of 61.47 kmol/hr superheated HPS at 385 degrees Celsius is 974.84995104 kW.
Now the problem is, the HPS cannot be considered to be in an ideal state at 45 bara whereas the natural gas mixture at 370 degrees Celsius  can be. If the HPS is considered ideal and the Enthalpy difference and iteration method used to compute the mixture temperature, it results in a very high mixture temperature(exceeding 1000 degrees Celsius).
So I reckon there is another way to calculate the mixture temperature since one of the mixture constituent (HPS) is non ideal at the stated conditions.
#136 PingPong
PingPong
  • 1,474 posts
Posted 20 February 2018 - 10:47 AM
Read my message #124 again.
#137 ravindra@096
ravindra@096
  • 41 posts
Posted 21 February 2018 - 08:16 AM
The enthalpy of natural gas at 370 ⁰C = 92.69120381 kW
The enthalpy of HPS at 385 ⁰C and 45 bara = 191.2848688 kW
The addition of above enthalpies = 283.9760726 kW
The mixture (HPS + NG) temperature at which the enthalpy summation equals the enthalpy of the NG at 370 ⁰C plus enthalpy of HPS at 385 ⁰C = 380.4741 ⁰C
The enthalpy of natural gas at 550 ⁰C = 155.6321235 kW
The enthalpy of HPS at 550 ⁰C and 45 bara = 310.1592558 kW
Heat duty for heating the mixture from mixture temperature to 550 ⁰C = 465.7913793-283.9760726 = 181.8153 kW
#138 PingPong
PingPong
  • 1,474 posts
Posted 21 February 2018 - 10:37 AM
The mixture of natgas + recH2 + HPS with an enthalpy of nearly 284 kW will have a much lower temperature.
It is not clear to me what you are doing here.
The enthalpy of the reformer feed at XOT has already been calculated by you weeks ago. Look that up.
Edited by PingPong, 21 February 2018 - 10:40 AM.
#139 ravindra@096
ravindra@096
  • 41 posts
Posted 21 February 2018 - 11:22 AM
How we do we calculate the mixture (HPS + recycle H2 + NG) temperature then ? The NG plus recycle H2 is at 370 degrees Celsius and the HPS at 385 degrees Celsius.
Is the (NG+ recycle H2) enthalpy at 370 degrees Celsius correctly calculated ?
Is HPS enthalpy at 385 degrees Celsius not correct ?
#140 PingPong
PingPong
  • 1,474 posts
Posted 21 February 2018 - 12:41 PM
The 284 kW for the mixed feeds is correct, but the mixed temperature will be much lower than 380.47 oC.
I can't see what went wrong in your calculation of the mixed temperature.
#141 MurtazaHakim
MurtazaHakim
  • 110 posts
Posted 22 February 2018 - 06:05 AM
The mixture temperature is 354.01 degrees Celsius when the temperature value is varied in the table created weeks ago for calculating the reformer inlet enthalpy at 550 degrees Celsius (478 kW). However when we calculate the enthalpy separately at a common temperature x for natural gas and HPS (from steam table) and add them later,we do not get the desired mixture temperature.
The heat duty obtained for heating feeds from 370 to 550 degrees Celsius is 478.5397221-283.9757117 = 194.5636495 kW
The enthalpy of mixture at 550 degrees Celsius has been calculated very early in the heat balance however when we calculate the same enthalpy at 550 degrees Celsius separately for NG and HPS (from steam table) and add them,the resulting summation is around 465 kW and not 478 kW. What could be the reason for that 13 kW drop in enthalpy of the mixture at 550 Degrees Celsius
What would be the next move if the above reported feeds mixture temperature and heat duty are correct ?
EDIT: The figure in bold is corrected.
Edited by MurtazaHakim, 22 February 2018 - 08:28 AM.
#142 PingPong
PingPong
  • 1,474 posts
Posted 22 February 2018 - 07:52 AM
Once again: HPS at 385C/45bara is not an ideal gas.
As you can verify in a steam table it has the same enthalpy as steam at 346 oC and nearly zero pressure (ideal gas).
If you would let the HPS down to nearly zero pressure its temperature would drop to 346 oC. That is the Joule-Thomson-effect.
For the natural gas at 370 oC it feels like it is mixed with steam at 346 oC and therefor the mixture temperature is 354 oC (assuming the natural gas and the mixture were ideal gases). The real mixture temperature is more like 365 oC because due to the high steam content in the mixture it is not really an ideal gas. In other words: if you would let the mixture at 365 oC down to nearly zero pressure its temperature would drop to 354 oC (JT-effect).
HPS at 550 oC is not an ideal gas so if you heat NG and HPS separately to 550 oC and then combine them the mixture temperature would be lower than 550 oC. To bring the mixture to 550 oC would require additional duty, roughly that 13 kW.
The heat duty obtained for heating feeds from 370 to 550 degrees Celsius is 478.5397221-283.9757117 = 193.5636495 kW
You mean 194.56 kW.
The preheat duties that you calculated are good enough for the moment. Later you can try to include effect of non-ideality if you would still have time and energy for that.
Now you need to look at available waste heat in flue gas and WGSR effluent, and determine how you can use that for feed preheat, steam superheat, BFW preheat, additional HPS generation for export (and consequently more BFW preheat) and, if you have waste heat left, consider air preheat.
#143 MurtazaHakim
MurtazaHakim
  • 110 posts
Posted 22 February 2018 - 09:15 AM
The enthalpy of WGSR effluent at 420 °C is 422.6 kW and at the condenser temperature (45 °C) is 20.2232 kW which provides around 402.3768 kW  of heat.The enthalpy of flue gas (by burning FG + tail gas) at 1000 °C is 1449.997201 kW.
What would be the outlet temperature of flue gas at which we must find its enthalpy and the difference of both would then give us the available heat for fulfilling the duties ?
Edited by MurtazaHakim, 22 February 2018 - 09:16 AM.
#144 PingPong
PingPong
  • 1,474 posts
Posted 22 February 2018 - 10:38 AM
It's not as simple as that.
At any point in the heat integration the hot temperature has to be higher than the cold temperature.
You should be familiar with Pinch Technology.
#145 MurtazaHakim
MurtazaHakim
  • 110 posts
Posted 23 February 2018 - 10:11 AM
The pinch analysis requires the process streams to be divided into source and sink. In our case, WGSR effluent and flue gas happen to be the sources and NG+recycle H2,mixed feed and BFW appear to be the sinks. The method I came across requires a table to be created having the stream,its supply temp.,its target temperature,the available heat it possesses and the final parameter is kW/K which is the heat needed to be delivered/received in order to achieve the target temperature. Comparing the kW/K for source and sink should give the waste heat used. If dimensional analysis is performed we get the same kW/K by having (Cp*F)/3600 where Cp is in kJ/kg.K and F is the mass flow rate in kg/hr. The dimensional analysis form can be used for computing kW/K of sink since the sink flow rates are known and the values of kW/K of both (source and sink) could be compared. The Cp value is however a function of temperature and it would thus be difficult to have an average Cp over the temperature ranging from supply to target.Please see the attached thumbnail. I have arbitrarily divided the flue gas enthalpy into 1000 and 500 kW for the stated streams since one stream (NG + Rec. H2) had lesser flow rate.
 Am I heading in the correct direction ?
#146 PingPong
PingPong
  • 1,474 posts
Posted 24 February 2018 - 10:32 AM
I have no idea what that means so let's assume that it is not correct.
You did not mention steam superheat duty.
If you want to recover as much waste heat as possible, as you stated a few weeks ago after consulting your supervisor, then you need to generate additional HPS and superheat it. That means also additional BFW preheat duty required.
You may also consider combustion air preheat.
How you are going to do all that is up to you. You can do it using Pinch Technology, or a simpler approach, or just using common sense. This is your project so I am going to let you figure it out yourself for the coming week or so.
In any case it is handy to make graphs with T on horizontal and H on vertical axis for individual streams. Or composite curves if you use Pinch.
#147 MurtazaHakim
MurtazaHakim
  • 110 posts
Posted 24 February 2018 - 10:52 AM
The flue gas is utilized to heat two streams,(NG+recycle H2) from 43 to 370 degrees Celsius and mixed feeds from 365 to 550 degrees Celsius. How would the available heat in flue gas be distributed in that case ?
We are interested in heat integration using pinch analysis. How do we begin the pinch analysis ? I mean how do we generate the composite curves ?
#148 PingPong
PingPong
  • 1,474 posts
Posted 25 February 2018 - 04:42 AM
I mentioned Pinch because I thought you might already be familiar with it. The internet is full with info on it, for example google: pinch technology composite curves. Use also google images and youtube.
However if you are not at all familiar with Pinch, then I think you better use common sense and trial-and-error to figure out how to make best use the available waste heat. In that case, to keep it simple, use the WGSR effluent only for BFW preheat so that you can concentrate on flue gas heat for all other streams.
Some time ago I posted here a link of another SMR topic that may give you some ideas.
#149 ravindra@096
ravindra@096
  • 41 posts
Posted 27 February 2018 - 12:38 AM
For the cold stream, should we select 65.244 kmol/hr BFW at 30 degrees Celsius supply and 242 degrees Celsius target temperature (saturated liquid at both Ts and Tt) for receiving the heat of WGSR effluent ?
The 65.244 kmol/hr was calculated on the basis of estimations followed in the preceding discussions related to SD and WHB.
Should the flue gas be considered as a hot stream (its target temperature is unknown) ? We have so far considered two hot streams namely reformer effluent with Ts of 850 °C , Tt of 353 °C and WGSR effluent with Ts 420 °C, Tt 45 °C.
#150 PingPong
PingPong
  • 1,474 posts
Posted 28 February 2018 - 04:41 AM
Keep BFW preheat using WGSR effluent for last. Until you decided how much additional HPS you can/want to generate and superheat in the furnace convection section you can't calculate how much BFW you need to preheat anyway.
Yes, it is a hot stream without a real target. You can take as much heat from it as you need, but you do not want a stack temperature below say 150 oC.
Again: look at that other SMR topic for ideas.
