We are designing a continuous fermenter which would grow bacteria with growth rate of 0.5 g/l/h . The maximum concentration we can have in the tank is 60 g/l of the bacteria in media. we need to produce at least 1100 kg/h of these bacteria. how can we calculate the volume of the bubble column reactor ?
Fermenter Volume
Posted 12 March 2018 - 11:56 PM
Posted 13 March 2018 - 10:43 AM
you need to solve a differential equation based on bacteria mass balance and retention time. Media flow is constant.
bacteria concentration changes with time.
Posted 13 March 2018 - 07:33 PM
Any sources that I can study about that ?
Posted 13 March 2018 - 09:06 PM
60 g/l ---> means you are removing 18333 l/h (1100 kg/h divided by 0.06 kg/l)
Growth Rate: 0.5 g/l/h ----> For steady state you need to produce the same as you remove.
So you need: 1100 kg/h / 0.0005 kg/l/h. That is: 2200000 lts or 2200 m3
And 2200/18.333 gives you a retention time of 120 hours.
For a "bubble column" it looks big.
Posted 13 March 2018 - 11:21 PM
yeah that's how we calculated it too and yes that's what we concluded that the reactor will be too big. Just wanted to make sure we are calculating it right. I don't know why our client keep saying we are wrong and the reactor should be much smaller :/
thanks for your help
Posted 15 March 2018 - 07:05 AM
It is a accumulation not simply linear increasing.
Edited by rikakose, 15 March 2018 - 07:15 AM.
Posted 15 March 2018 - 07:29 AM
mt(dt)=integral(0-t)(C0+S*dt)*F*dt
C0 initial concentration
S growth rate
F flow
mt bacteria mass
retention time is around 16 hours.
Edited by rikakose, 15 March 2018 - 07:51 AM.
Aspen Hysys Simulation Issue With Pfr Reactor Volume: Seeking AdviceStarted by Guest_naduken_* , 27 Apr 2023 |
Natural Gas Wells Location And Production Volume DataStarted by Guest_ChinmoyBasak_* , 08 Feb 2023 |
Barometric Condenser Hotwell Volume DesignStarted by Guest_zorro1234_* , 13 Jan 2022 |
Volume Of Shell In Kettle Type ReboilerStarted by Guest_ProcessEng_12_* , 09 Nov 2021 |
How Can I Calculate The Volume Of Nitrogen Required?Started by Guest_Engrabiolabusari_* , 13 Jul 2021 |
