Pressure Drop Verification
#1 Blank03
Blank03
  • Validating
  • PipPip
  • 16 posts
Posted 19 May 2018 - 02:04 AM
Hi good day :)
I would just like to verify if my answer is correct on this one. I do apologize if some of you might think that "oh this is just very simple how could she be so unsure with the answer?"  hahaha. I am, you see, very conscious that MAYBE there might be some hidden question between the question.
So the question is this:
 The pressure drop in a 6-in. pipe (I.D. = 6.065 in.) of length L is 1 psi with the flow in the highly
turbulent region. If the same liquid flows at the same volumetric flow rate in a 3-in. pipe (I.D. =
3.068 in.) with length L, the pressure drop (psi) is most nearly:
what i did is the fact that P1/p2=(d2^5)/(d1^5) as i equate it from the original pressure drop formula.
so 1/x=(3.068^5)/(6.065^5). that is 30.
uhm am i correct?
thank you very much everyone! :)
  • 6,348 posts
Posted 19 May 2018 - 02:25 AM
https://bae.okstate....-WeisbachEq.htm
Apply the Darcy Weisbach equation .
calculation is a piece of cake then !
Note : the result is correct  , you should simply write :  Delta P2 =Delta P1 * ( D1/D2)^5
Edited by breizh, 19 May 2018 - 09:31 PM.
#3 fallah
  • 4,954 posts
Posted 19 May 2018 - 02:29 AM
Blank03,
With the conditions you described (same flow) and neglecting the change in f (friction factor) appears your result for pressure drop in 3" pipe equal to 30 psi is correct...
#4 Pan Nata
Pan Nata
  • 34 posts
Posted 21 May 2018 - 02:10 AM
Blank 03,
Yes, you are.  The pressure drop in the 3" line shall be around 30 psi empirically, neglecting the friction factor and any line elevation.
Good luck.
#5 breizh
  • 6,348 posts
Posted 22 May 2018 - 04:42 AM
Hi P N ,
Please read what Naser offers !
Your statement is incorrect.
