Hi all,
Could you give ideas or suggestions in order to fixed my simulation?
I appreciate your comments.
Thank you.
Posted 16 August 2018 - 02:12 PM
Hi all,
Thank you.
Posted 16 August 2018 - 02:55 PM
You cannot accurately model this with Peng Robinson. You need an electrolyte model to deal with the aqueous phases and reaction therein. OLI has software that can do this, either standalone or as plugins to Unisim, Aspen HYSYS or Aspen Plus.
Posted 16 August 2018 - 03:08 PM
I know that electrolyte model is the best option, but my company don't have the licence for that. We have to use the available Unisim's tools in order to obtain the process, with more error for sure.
Any other suggestions? I'm very limited with the software.
Edited by Cleomari, 16 August 2018 - 03:12 PM.
Posted 16 August 2018 - 04:18 PM
If you lack the correct modelling tools, why bother?
Posted 15 August 2019 - 05:36 AM
Posted 15 August 2019 - 01:48 PM
Just look at the date of the last reply.....it's been a year
with hysys v11. you should acid caustic wash fluid package ..
with unisim maybe use oli package
pengrobinson is equation state . its not available with ion .
with ion sysystem .you should use model ( such as Exnrtl,oli,elec nrtl,uniquac,unifac
Process Plant Insights Dot ComStarted by Guest_Pilesar_* , 08 Sep 2026 |
Acetic Acid Plant Using The Cativa Process.Started by Guest_Pilargalizia_* , 02 Jul 2026 |
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , 18 Jun 2026 |
Ai For Designing Of Process PlantStarted by Guest_Biomass Process_* , 12 Jun 2026 |
Process Engineers / Mechanical Engineers - ResponsibilitiesStarted by Guest_PhilippM_* , 10 Jun 2019 |
