Dear All
I'm study Ethylene storage tank process whereby the discharge liquified Ethylene (-102 degC, TDH = 20Bar(g)), pump to pipeline, throtling through control valve and undergoes heating/evaporator and final discharge in vapor phase at 27 to 31 deg C.
Since the Ethylene is extremly cool, around -104 to 102 deg C, rundown from storage tank.
Ethylene flow rate = 15,000 to 25,000 kg/hr, liquid density = 566 kg/m3 at 164K
Heat Capacity = 2.27 Kj/C
Available steam/utility supply:
Design condition: 1.6MPa / 250 degC
Saturated steam, at Op, Pressure = 0.5 to 1.2MPa
Let say used 150 deg C
Can anyone advise me:
a) What is the best heat exchanger type we can use? (I would think is Kettle Reboiler type??)
The process stream / Shell side inlet temp is -102 deg C. I don't have any plant/process data. Can someone advise me what is the realistic Ethylene liquid (process stream) inlet temp/pressure?
Evaporator Type Heat Exchanger To Heat Up Etylene
Started by Dtan76, Sep 13 2006 03:04 AM
No replies to this topic
Posted 13 September 2006 - 03:04 AM
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , Yesterday, 05:29 AM |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
