Bubble And Dew Point Pressure Of A Mixture
27 replies to this topic
#26 IllusionistXY
IllusionistXY
  • 6 posts
Posted 24 November 2018 - 03:47 PM
PingPong:
I guess you are right cause I used a software that calculated the dew point but wasn't able to calculate the bubble point. It gave an error.  Is it possible to explain why a bubble point wouldn't exist?  is it because when speaking about bubble point, one should have a mixture of liquid components?!  in other words, H2 also need to be in a liquid state?
It would be great if you could  recommend a reference so that I can better understand this.  I am not expert in thermodynamics unfortunately and I need to finish these calculations.
And last thing, say that I know that outlet temperature of the condenser.  Do I  use this temperature to calculate the enthalpy of condensation or do I use the dew point temperature?
Thank you in advance ..
#27 breizh
  • 7,000 posts
Posted 24 November 2018 - 10:28 PM
hi,
you may find answer using this link .
http://www.questcons..._and_dew_points
Hope this is helping you
#28 PaoloPemi
PaoloPemi
  • 550 posts
Posted 25 November 2018 - 02:48 AM
you should open a different thread when introducing a new problem :-)
anyway, I agree with PingPong and others, many solutions available, you can, for example,  solve a flash operation with a specified amount of a component in vapor or liquid or solid phase...
or you can (as suggested by Breitzh) calculate a VLL (three phases)  phase envelope / diagram to identify the point of incipient condensation / evaporation of third (water) phase,  see for example
https://www.prode.co...aseenvelope.htm
but there are many other examples at cheresources.com ...
you should first determine the problem, then we can help to solve it...
