Flash Calculation
Posted 14 January 2019 - 06:18 AM
Please I used Vout= Vpe+YVtk^0.9Ri
But it says I have to get the flash calculation
Posted 14 January 2019 - 07:05 AM
Hi Iquaye,
Quite difficult to understand your post . Please revert to the document attached to solve your query .
flash point of your product . please use your favorite search engine to understand the requirement .
Hope this is helping you.
Edited by breizh, 14 January 2019 - 07:07 AM.
Posted 14 January 2019 - 10:51 AM
Posted 14 January 2019 - 10:52 AM
Iquaye:
Please be frank and open with our members. Are you an engineering student in Ghana? If so, I can move this thread to the Student Forum where you can receive our member's help and advice on how to solve a Flash operation as it applies to a conservation vent or relief device.
But you must be open and explain your query in detail. The more detail and basic data that you give our experienced members, the better and more applicable the help. If you are a student and have been assigned this as a homework or other problem, then tell us. The nature and simplicity of this query is easy to resolve - but more details and an explanation is needed. Our Forums don't do homework or teach Thermodynamics, but we can help you understand the nature of the problem and lead you to your resolution.
Are you flashing into the (storage) tank? If so, what are you flashing (in detail)? Where did you obtain the equation? Furnish an engineering sketch to show the details of your problem. What - exactly - is it that says you "have to get the flash calculation"???
And kindly stop making multiple postings of the same topic. I deleted your other posting.
Expect your reply.
Posted 14 January 2019 - 01:15 PM
I have done the calculation but am not sure of the figures am getting.
Thank you.
Posted 14 January 2019 - 03:15 PM
Iquaye:
That's OK. We are both engineers, so lets use our engineering common sense. We now know that you've already done the calculations. The simplest and easiest engineering manner to confirm the applicability of the calculation results is to submit your calculations for review and check-ups. This is the normal, everyday method of confirming engineering calculations world-wide. Simply submit to our Forum members your calculations (legible and in detail), and they will immediately know what the application is and determine if your calculation steps are valid and reasonable. This can be done by using our Forum's detailed Reply Option. It would be great and result in an immediate reply if your calculations can be submitted in an Excel spreadsheet, where they are not only legible, but also automatic in the mathematical steps.
Await your reply.
Kerosene Flash Point TroubleshootingStarted by Guest_zuberattan_* , 25 Oct 2009 |
![]() Flash Seperation For N-Butane IsomerizationStarted by Guest_CHEMICAL_LOVER_* , 04 Dec 2024 |
