I want to find heat transfer area of plate type heat exhangers.
how to find it with plate dimensions.
if anyone have formula sheet for the same it will beneficial for me
I have attach image of that HE
Thank you
Posted 07 February 2019 - 02:01 AM
Thank you
Posted 07 February 2019 - 02:14 AM
No picture attached !
you may consider the document attached together with your text book .
Other good references : Perry's chemical engineers' handbook .
https://www.cheresou...eat-exchangers/
Good luck.
Edited by breizh, 07 February 2019 - 02:53 AM.
Posted 07 February 2019 - 04:36 AM
Dear Sir,
Now i have attached image of that HE.
Please give me calculation details about this type of PHE's i.e circular type PHE.
Thank you.
Posted 07 February 2019 - 06:26 AM
http://www.sondex-us...kelt sidet2.pdf
For those interested I believe the plates are similar to those in the brochure .
I cannot offer more .Did you check with the vendor /manufacturer ? what about the spec sheet of this equipment if already in service .
note 1 : by analogy with rectangular plates ,
Hydraulic diameter =4 * S /P
S = area available for the stream passing between 2 plates
P = wetted perimeter between 2 plates
note 2 : HTRI software should be an option to support tyour work.
Edited by breizh, 07 February 2019 - 06:38 AM.
Electric Heat Tracing—Pipe-Wall Temperature Vs. Actual Fluid TemperatuStarted by Guest_zamakaze_* , 20 Sep 2026 |
Screening Heat & Material Balances Cases For Fire Relief Psv SizinStarted by Guest_powerox6_* , 21 Aug 2026 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
