Dear All
Is it possible to incinerate BTEX stream (waste stream of TEG regenerator) in flare stack of plant. How to determine if ignition of this stream is possible in flare stack, keeping in view the higher water content. Composition is attached.
Posted 31 March 2019 - 08:39 PM
Dear All
Posted 01 April 2019 - 07:05 AM
Might I suggest strip out the volatiles to flare first, then send the remaining liquid waste to wastewater treatment plant. I think it would be a lot cheaper than incinerating the entire stream, if 50+% water is even incinerable in the first place...
Thermal Oxidizer HeaderStarted by Guest_ryn376_* , 29 Jan 2026 |
Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
Flare And Venting SystemStarted by Guest_miz19_* , 10 Jul 2024 |
