Tubing Vs Piping Under As4041
#1 black friday
black friday
  • 55 posts
Posted 01 April 2019 - 09:26 PM
Hi all,
I just wanted to check my thought process. I'm dealing with a fitting that is only readily available in sizes suitable for tubing.
If I were to use tubing to allow me to use these fittings, instead of piping, would I still use the same method to determine pressure rating under AS4041?
I'd just spec the wall thickness using the AS4041 version of Barlow's formula and then exceed that as I would with piping?
Thanks!
Posted 02 April 2019 - 12:33 PM
Since you give no information on your community stats, I have to assume you reside in Australia since I believe Standard AS4041 is a 330-page Australian pressure piping standard.
With all due respect to Australia, I don't think a lot of people outside of Australia are familiar with that standard.  I am not and so, I believe, are a lot of our members.
However, if I were in your place, I'd use Barlow's Formula to determine the maximum pressure the selected tubing would be expected to take and if that is below the working maximum pressure expected to be applied, I'd use the tubing.  The smaller the tubing, the higher the maximum allowable working pressure it can take.  I've used tubing on hydraulic and other high pressure lines up to - and exceeding - 5,000 psig.  But not with reference to AS4041.
#3 black friday
black friday
  • 55 posts
Posted 02 April 2019 - 04:36 PM
Thanks Art, you've confirmed my assumptions.
