Its going to be a long but descriptive post which entails my case study for an x3 effect CaCl2 steam evaporator. Feed of 28w.t% is concentrated to 60w.t%. Properties of CaCl2Brine (not solid) are taken from DIPPR to create an hypo.
I used extended NRTL for every case study with no BIPs info for now
pfd.jpg 45.61KB
2 downloads
In the Case#1: no modifications were made to the setup. It was realised that Specific Mass Heat Capacity kJ/Kg/K (Cp) of aqueous mixture is predicted very high at different w.t%. In the last column (table pic attached latter) you will see Cp value ranging from 3.8 - 3.3 (from literature it should be b/w 2 - 3).
To rectify the over-predicted Cp issue I experimented with Tabular properties.In the Case#2: I did this & it rectified my Cp problem (I DON'T KNOW HOW?). However my Mass Density kg/m^3; got highly under predicted.
tabular_case1.jpg 73.87KB
1 downloads
From the SimBasis literature; I got this which indicated that physical properties can be adjusted using (what I understood) sort of a fudge factor (Mixing parameter)
fudge_.jpg 80.51KB
1 downloads
I experimented & a factor of 1.3 gave reasonable results of Mass Density (at different temps & w.t% solutions). This fudge factor will be used to correctly represent density in both Case#2 & #3
tabular_case_density_common.jpg 76.72KB
1 downloads
Again from the SimBasis literature
tabular_req.jpg 67.95KB
0 downloads
So in Case#3 I tried changing these parameters (instead of Liq & Gas Enthalpies as in Case#2)
tabular_case2.jpg 76.76KB
0 downloads
Final results...
table.jpg 124.75KB
0 downloads
Questions (& observations)
1] A higher steam consumption in #1 is due to higher Cp HYSYS predicted of aqueous solutions? I think yes because each separator T & outlet w.t% are practically similar for all cases
2] Why by just checking default values of Enthalpy(L, G) in #2 reduced Cp (& corrected problem)? Some details are highly appreciable
3] #2 & #3 is one & same thing? For all practical reasons the results are similar
4] Is my labeling of Mixing Parameter a fudge is OK?
5] Is there an alternative to adjust Cp without experimenting with Tabular properties? While creating a Hypo which property highly effects Cp prediction? (by fudging that I willn't go to Tabular properties at all)
________
PM me if you need HYSYS case files. It has company info so cannot share publicly
Edited by IonCube, 26 April 2019 - 05:14 PM.
