Flow Meter And Totalizer
#1 bbilika
bbilika
  • 3 posts
Posted 03 May 2019 - 08:03 AM
Have a question on a flow meter/totalizer that is adding totals when in the process line there is no flow or its on maintenance. The flow meter is used to measure
  • CO
  • HYDROGEN
  • NITROGEN
  • CO2
  • METHANE
  • OXYGEN
#2 thorium90
thorium90
  • 1,073 posts
Posted 03 May 2019 - 08:06 AM
Adjust the low flow cut off setting.
#3 breizh
  • 7,038 posts
Posted 03 May 2019 - 08:25 AM
hi ,
What type of meter is it? How totalization is done ?
If you look at the manual you should get your answer and it's probably good to talk to your E&I engineer and Vendor of the instrument who is very familiar with this issue.
Good luck.
#4 thorium90
thorium90
  • 1,073 posts
Posted 03 May 2019 - 08:47 AM
Also, that's one helluva of flowmeter you got there, that measures CO, H2, N2, CO2, CH4 and O2 all at the same time in the same line?
What's the line supposed to be? Syngas?
Almost looks like syngas, but the O2 threw me off.
Flowmeters can indeed measure gas mixtures, but your gas mixture is rather peculiar.
Anyhow, do you have a picture, video, sketch etc., of the problem you are seeing?
Edited by thorium90, 03 May 2019 - 08:52 AM.
#5 bbilika
bbilika
  • 3 posts
Posted 08 May 2019 - 09:14 AM
This is the kind of flow meter attached
#6 breizh
  • 7,038 posts
Posted 08 May 2019 - 08:56 PM
You are not helping us, you don't supply any info about the technology , better to talk to the manufacturer .It seems to be a Chinese brand . DP transmitter ?
good luck
Edited by breizh, 08 May 2019 - 08:59 PM.
#7 breizh
  • 7,038 posts
Posted 09 May 2019 - 06:02 AM
This transmitter is Rosemount DP type , Google search , you should contact EMERSON  , they should fix your problem.
Good luck,
