Path Meaning In Indirect Bath Heater
#1 pinakini
pinakini
Posted 31 August 2019 - 06:55 AM
I am new to this forum.
I am working for a project where client has mentioned following details for Coil:
5.0 Pressure Coils:
5.1    No. of Coil: 1(one)
5.2    No. of Pass/path: 14 (fourteen) passes.
5.3    No of Path: 5 paths
5.4:   Coil size: 4" (101.6mm) NB x 0.337" (8.55mm) wall thickness (Schedule 80)X 8.5 Mtrs long
5.5:   Header Pipe size: 8" NB, OD: 8.625", Schedule: 80
5.6:   Coil Material: Seamless pipe as per API-5L Gr. B, / ASTM   A106 Gr. B .
5.7    Coil Operating Pressure: Max:  105.46 kg/cm2 (1500 psig)
5.8    Coil Hydraulic Test Pressure: 1.5 times the maximum working pressure
5.9    Radiography of weld joints of Coil bundle: 100 %
Please clarify what is the meaning of path here.
#2 Bobby Strain
Posted 31 August 2019 - 09:06 AM
You should ask your client.
#3 fallah
  • 5,026 posts
Posted 01 September 2019 - 03:12 AM
5.0 Pressure Coils:
A coil divided to several paths and each path is composed of several passes...
Edited by fallah, 01 September 2019 - 05:11 AM.
#4 breizh
  • 6,924 posts
Posted 01 September 2019 - 06:30 AM
http://www.nigc-tpgc...a6-b4f1e399d408
To add to Fallah's reply , consider the link above .
As suggested , your customer or manager should support your query . Anyway you still have the possibility to consult vendor for support .
let you use your favourite search engine to find out vendors .
http://www.garcem.in...th-heaters.html
https://www.google.c...iw=1536&bih=754
Edited by breizh, 02 September 2019 - 03:34 AM.
