Hi to all,
How can i size the separator for below condition. pressure @2.5kg/cm2_g temp - 25 degree C.
Feed GAS OIL WATER Flow (t/d) 357.51 659.33 2425.00 Density (kg/m3) 1.90 923.50 990.09 Viscosity (cP) 0.01 288.39 0.53
which separator will be good either two phase or three phase.
If i design three phase separator, it will be too big.
Droplet Size (m) Oil in Gas 150.00 Droplet Size (m) Oil in Water 200.00 Droplet Size (m) Water in Oil 2000.00
(In this process, after the three/two separator heater treater is used to separate oil)
