Psv Sizing For Progressive Cavity Pump.
oversize of psv
#1 npparab12
npparab12
Posted 13 March 2020 - 06:03 AM
PSV Sizing for Progressive Cavity pump.
Operating Flow rate is 65.3 m3/hr at Selected RPM of 265
Flowrate at Max. pump speed (300rpm) Ex area = 75m3/hr. as per pump curve.
Pump Design is for 400rpm with flowrate of 120m3/hr.
1. I have received the Vendor Doc for PSV Sizing Calc for 120m3/hr.
My question is if we have selected the Pump to work with maximum speed of 300rpm & 75m3/hr then PSV should be sized for 75m3/hr. This will be the worst cases scenerio for pump Right / Wrong ? sizing for 120m3/hr will never be the case.
2. The PSV Orifice Size Calculated is 3.49 sqinch. But Vendor has selected Q with 12.91 sq.inch. Stating a reason as, 'Oversize due to 6" inlet connection and 8" outlet connection. Acceptable for the requested flowrate.'
Usually we select PSV one size higher and then Size the Inlet /Outlet Line base on pressure drop and MACh no.
Request for guidance.
#2 latexman
  • 1,922 posts
Posted 13 March 2020 - 06:36 AM
How is speed controlled?
Mach number, in liquid service?
