Hi all,
for a high viscosity fluid application, is it possible to install an air operated diaphragm pump at the suction of the lobe pump.
Considerations -
1. Lobe pump location can't be changed.
2. Tank can't be charged with high pressure.
3. With that lobe pump being fixed at a same location, pressure drop in that line is very much high, lobe pump may not be able to pump the liquid.
4. Lobe pump is connected with a hose, taking advantage of that if an AODD pump is placed the suction pressure drop can be halved, and AODD pump will give enough pressure at the lobe pump suction so that it doesn't starve.
5. Discharge pressure is high, AODD Pump will not be able to push the liquid to that far.
I am attaching the pump arrangement with this. Let me know your views.
Sketch link -
https://drive.google...iew?usp=sharing
Edited by raj shekhar, 08 June 2020 - 02:07 PM.
