Cooling Tower Performances Follow Up
#1 fredlan54
fredlan54
  • 8 posts
Posted 08 July 2020 - 09:17 AM
Dear all,
What would be your recommendation in order to follow up a cooling tower performances ?What are the key parameters to measure in order to evaluate its performance over time ?
Thanks in advance for your help,
Sincerely,
Fred
#2 Bobby Strain
Posted 08 July 2020 - 10:42 PM
You must periodically measure the variables from which you can calculate performance. I recall decades ago there was a cooling tower institute. You should check it out.
#3 breizh
  • 6,348 posts
Posted 08 July 2020 - 11:26 PM
Let you try the search engine in this forum , a lot of information have been posted .
You should get good input from the vendor of chemicals in charge of the treatment  for your cooling tower(s) , he should perform regular checks and provide a report about the quality of the treatment and give advices ( monthly basis) .
https://www.suezwate...g-water-systems
a few tips :
*make sure the distribution of water on the packing is good ( visual inspection)
*install a corrosion rack to ensure the treatment is good for all metallurgy ( supplied by chemicals treatment vendor)
* During turn around inspect a critical HX to ensure the chemical treatment is performing well ( no deposit, no corrosion ), Chemicals vendor  should widness the operation .
* check regularly the vibrations of the fan(s) , good to have a 24h monitoring
* make sure the louvers are working well to prevent loss of water
* Good to have strainer(s)at the suction of the pump(s) to prevent cloggage of line ,HX , regular check is a must to mitigate the risk of cavitation.
* Good to filtrate  the cooling water to remove dirt, pollens, .... (side stream filtration) , depends very much of your location
* Winterization , good to have a by pass line to return part of the water to the basin to prevent freezing .
* Good to have a VFD to adjust the RPM of the fan(s) to save energy .
* Let you put in place a performances contract with the company in charge of the treament : number of cycles , chemicals usage , corrosion  (mils/year) ,number of visits per year ,...)
Don't forget to ask for a regular check of Legionella !  Chemals supplier should offer it .
Hope this is helping you , better if you have specific requests.
Edited by breizh, 09 July 2020 - 09:22 PM.
#4 fredlan54
fredlan54
  • 8 posts
Posted 09 July 2020 - 03:14 AM
Bobby and Breizh, thank you for your wise recommendations. They will be very helpful.
Sincerely,
Fred
