hi guys
i am new member ub ur forums
i now doing design for recovery of light product (propane, butane and gasoline) from a sream of different product. i wana use hysys, but i am not that much on it. do you have any idea that will help me
Light Product Recovery
Started by normal2500, Oct 24 2006 03:14 PM
Posted 24 October 2006 - 03:14 PM
Posted 01 November 2006 - 01:41 PM
Hi ......
First of all, if you wish to use HYSYS, you must first learn the basic principles of simulation in that simulator.
In addition, it is necessary data of the feed to the process: mass or volumetric flow, density, chromatographic analysis of the same current, pressure and temperature. with base of these data it is possible to try istart the simulation.
Posted 25 November 2006 - 10:55 AM
Hello Normal2500,
In order to achieve proper fractionation train design in Hysys, you certainly must be something more than ordinary software user. The best combination is: experienced field engineer and process simulator maniac, at the same time. If you are not familiar with process simulators, do not try playing games with distillation tower(s) design.
As you are probably aware, software will come up with a "perfect" solution for your demands, regardless of how (in)accurately the problem is defined in the first place (garbage in = garbage out). So, it is quite possible to retreive modeling results that look really great, but that pieces of equipment will not work at the field. Please contact your software vendor for assistance.
Posted 14 December 2006 - 08:24 PM
QUOTE (normal2500 @ Oct 24 2006, 03:14 PM) <{POST_SNAPBACK}>
hi guys
I think you are doing a separation in distillation column and this is simple , you can do it by habd or with HYSYS which very easy and you will get a very quick answer but you have to understant how to use HYSYS to avoid errors.
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Acidic Condensate In Sulphate Recovery By Vapour SeparationStarted by Guest_Ranga v_* , 09 Nov 2025 |
Opportunities For Heat Recovery In A Chemical Process PlantStarted by Guest_tanyongboon1_* , 29 Nov 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
