I have a few questions regarding the crystallisation process.
We have dimensionless numbers that describe the type of flow and other fluid properties as well.
I was wondering if this dimensionless analysis has been extended to understand the crystallisation process?
If not, is it even possible?
I actually use protein crystallography, which is a more complex process than the chemical, small molecule crystallography, although they share some of the principles.
Also, I am interested to know if there's a way to describe the chemical properties of the crystallization conditions used in protein crystallography into one dimensionless number?
As an example, the conditions typically used are :
5-35% of PEG 3350, sometimes with ions (MgCl2), a buffer component (100 mM of HEPES) at a designated pH (7.5)
Many thanks!
