Emergency Shut Down Procedures For Distillation Column
#1 JaiEdi
JaiEdi
  • 23 posts
Posted 14 March 2021 - 06:46 AM
Hi
I can't find any emergenncy shut down procedures that  would apply to distillation columns. Any general literature or advice on what these are? Specifically on the distillation columns in a deethanizer first Olefin plant.
Other than use total reflux and a recycle line from the overhead of the columns that feeds the Compression stages, is there much else to do with the start up of this?
Also based on what I have found there is not much on the start up procedures for the associated refrigeration cycle. Other than rate of cooling can be 50 deg C per hour and it would be turned on before the chilling train is initiated. Any advice?
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 15 March 2021 - 01:32 AM
If it is an emergency shutdown, like you said, then the setup is fairly straightforward:
  • Isolate the system with emergency isolation valves
  • Stop energy supply to the reboiler
  • Depressurize inventory to the flare
"Emergency" means complete cease of operations and subsequent release of hydrocarbon inventory to a disposal system.
#3 fallah
  • 5,026 posts
Posted 15 March 2021 - 05:06 AM
As always, a comprehensive reply by Dejan; but i want to add one more point:
If emergency shutdown is due to fire case it's highly preferable to keep the inventory inside the column after depressurizing, at least, to postpone the column failure...
