Hi, I am designing a multi-tubular packed bed reactor like a shell and tube heat exchanger. Do I need to model the reactor according to TEMA standards. For example, do I need to follow the constraint of 5<L/D<10 and maximum shell diameter of 2540mm ?
Multi-Tubular Packed Bed Reactor
Posted 17 March 2021 - 04:55 PM
Posted 17 March 2021 - 05:18 PM
Why not?
Posted 17 March 2021 - 05:42 PM
Posted 17 March 2021 - 10:14 PM
TEMA standards are an easy way for exchanger manufacturers and exchanger purchasers to understand what is being sold. The standards make it simpler for vendors to bid and for the purchaser to compare bids between vendors. Different specifications other than those conforming to the TEMA norms can be agreed upon by both buyer and seller. Those 'exception' specifications are noted in the contract. Heat exchangers built with 'exceptions' may suit the purposes of the buyer better than conforming to TEMA standards. The buyer can ask for equipment to be manufactured according to any specifications desired. TEMA does not mention packed bed reactors and is not intended to guide design of packed bed reactors.
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
Packaging And Gas Velocity In Packed ColumnStarted by Guest_ChemEng_CristianoB_* , 25 Jun 2025 |
Steam Flow And Heating Time In Batch ReactorStarted by Guest_seagal6_* , 16 Jul 2025 |
Multi-Tubular Packed Bed ReactorStarted by Guest_shambola_* , 12 Feb 2025 |
Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
