Packed Column Diameter
packed
#1 TI-83
TI-83
  • 3 posts
Posted 21 March 2021 - 12:53 PM
hello all,
I am trying to size a packed column and I an using the Eckert generalized pressure drop correlation (GPDC) along with packed column pressure drop correlation chart. I have the pressure drop and I am solving for (Mass flow _Liq./Mass fow_gas)*(density_vapor/density_Liquid) so that I get the y-axis G_p. My question is that if the purpose of the packed column is to remove Methyl-Acetylene and Propadine from a mixture of other liquid components with the use of hydrogen gas, would I take into account only the liquid flow rates of  Methyl-Acetylene and Propadine as well as their density or i would also need to take into account all the other liquid flowrates and for the mass flow of gas I am only taking into account the mass flow of hydrogen gas going in.
thank you
Edited by TI-83, 21 March 2021 - 12:54 PM.
  • 1,609 posts
Posted 21 March 2021 - 02:31 PM
If I understand your question correctly, you should use the bulk liquid flow and the bulk vapor flow. Column hydraulics and pressure drop calculations are for the bulk fluids.
#3 TI-83
TI-83
  • 3 posts
Posted 21 March 2021 - 03:14 PM
Hello Pilesar,
1.) Thank you for your response , yes that is what I was wondering about. I asked that question because  when I use the bulk fluid and bulk vapor it gives me
 (M_L/M_G)*(density_V/density_L)^1/2 value of 155.2  which is not on the x-axis for the packed column correlation chart. as a reference im following the GPSA engineering data book.
2.) another question is for the viscosity (mu) i am assuming we use the viscosity of the bulk fluid as well and not that of  Methyl-Acetylene.
once again thank you for your response
#4 Bobby Strain
Posted 21 March 2021 - 04:35 PM
It sounds like you are designing a bubble flow reactor. It won't translate well to the usual packed column design. The reactors normally used for this are packed beds with co-current down-flow. For this you need different correlations.
Edited by Bobby Strain, 21 March 2021 - 06:27 PM.
#5 breizh
  • 6,887 posts
Posted 22 March 2021 - 08:31 AM
For packed tower design a few tools .
For hydrodynamic calculations you need to consider bulk liquid and bulk gas .
https://checalc.com/calc/packcol.html
