Distillation
#1 selvamvasudevan
selvamvasudevan
Posted 25 March 2021 - 12:56 PM
Feed is superheated and temperatures in enriching section is normal (sometime little bit high) but in stripping section temperature is going low. Product (liquid) draw is from side stream. This causes the carryover of low key to next tower. Suggest some actions.
#2 FRBChemE
FRBChemE
  • 35 posts
Posted 25 March 2021 - 04:46 PM
Have you tried modeling the distillation column with ChemSep?
Questions:  Is there a reboiler on the column?
does the side stream draw originate in the enriching or stripping secttion?  How many real trays or height of Packing?
#3 selvamvasudevan
selvamvasudevan
Posted 27 March 2021 - 10:51 PM
Modelling not tried.
Reboiler is there.
Side stream draw from enriching section.
102 trays
#4 horatorres
horatorres
  • 88 posts
Posted 03 April 2021 - 09:17 PM
Good Night
Some check you should perform
- column pressure drop
- Flooding signs en the nerby low temperatura trays
- Heat input in the reboiler, look the % of valve opening compare with normal operation
- Pressure damping into the top pressure meaurament
Look  and best regards
A process data   flow , feed composition, espected ans actual size product composition, plate sieze tray or valve tray, pressure and drawing colud be ussefull to help you
Horacio
#5 Kimron
Kimron
Posted 15 April 2021 - 01:19 PM
Check Bottom holdup and boil up.
