Oil And Gas Elevated Flare Turndown
#1 Becchis
Becchis
Posted 19 May 2021 - 03:46 AM
Hi everybody,
can anyone tell me the flowrate turndown for an oil and gas elevated flare?
I tried to find this information on API 521 and API 537 but I didn't find it.
Thank you for your answers!
Becchis
  • 1,603 posts
Posted 19 May 2021 - 06:16 AM
In general, flare systems are designed to maintain a non-flammable composition in the upstream piping even if the variable contribution from the process is zero.
#3 Becchis
Becchis
Posted 19 May 2021 - 07:28 AM
Thank you Pilesar for your reply.
Maybe my request was not so clear. I meant: which is the minimum flowrate that the flare can handle in comparison to the maximum flowrate? Something like 10% of maximum flowrate (turndown 1:10)?
I have experience where 5% of flowrate with high wind speed cause the flame to bend and damage the accessories on the top platform.
Becchis
#4 Pilesar
  • 1,603 posts
Posted 19 May 2021 - 09:22 AM
Flares get damaged and require inspection and maintenance. Flare designs differ and wind causes trouble. There is no general targeted turndown other than that required to control upstream flammability. Your individual flare system will have characteristics where it may not perform as intended under specific operating conditions. Flare vendors offer service to evaluate your system and will make recommendations for improvement. Flare tip design minimum flow should be available in the vendor documentation and the control system should maintain the requirements even if the variable flow from the process is zero. Sometimes the required flow changes as the flare equipment degrades from its original design. I have never seen a flare turndown 'rule of thumb' like you seek.
#5 breizh
  • 6,880 posts
Posted 19 May 2021 - 09:27 AM
You may consult these company : https://www.johnzinkhamworthy.com/
