Bogdanov Distillation
curve distillation curve bogdanov
#1 Novak
Novak
  • 7 posts
Posted 12 June 2021 - 12:35 AM
I have the Atmospheric residue defined by distillation curve as per "Bogdanov distillation, GOST 10120-71". Does anyone know how to convert this data to any standard curve like TBP, D1160 or similar to be able to input this into PRO/II? I thought it is equivalent to TBP but this is obviously not the case and the results of VDU simulation are pretty strange. Any advice on that?
Thank you!
  • 1,694 posts
Posted 12 June 2021 - 06:41 AM
I don't find a conversion method but I found the GOST 10120 procedure here: https://www.internet...sts/gost/37340/
Without an english translation, I don't understand the lab method. However, it may be possible to simulate the lab method itself in Pro/II and then determine what input composition is required to get your 10120 results. You would also need a standard characterization of simultaneous TBP and 10120 to calibrate the model. If I just needed a preliminary estimate, I would be tempted to just add the curve as a TBP and as a D1160 to try to get a ballpark range for the characterization and realize that the model would not be very accurate.
#3 horatorres
horatorres
  • 88 posts
Posted 13 June 2021 - 04:16 PM
Novak
This paper could help you... my friend
https://www.research..._Viscosity#read
https://pdfcoffee.co...e-pdf-free.html
Horacio
