Process Vacuum Condenser
Posted 26 January 2022 - 09:43 AM
Posted 26 January 2022 - 01:33 PM
If you are seeking drawings of the exchanger, your company should have these in records storage. If not, you can contact the fabricator for copies of their drawings.
Posted 26 January 2022 - 07:04 PM
HI,
It's a total condenser above the column where the liquid is collected in a circular pan attached to the wall . From this collecting pan the distillate is withdrawn (weir) . The bottom part of the pan is connected to a liquid distributor thus refluxed .
Note : you may have a chance to check the pan during a turn around .
The devil is in the details .
Posted 26 January 2022 - 08:14 PM
Distillation Column At Vacuum ConditionsStarted by Guest_FriendlyAlchemist_* , 21 Aug 2026 |
Process Plant Insights Dot ComStarted by Guest_Pilesar_* , 08 Sep 2026 |
Vacuum Total Condenser With Flooded Surface Control During TurndownStarted by Guest_unvecchietto_* , 02 Jul 2026 |
Acetic Acid Plant Using The Cativa Process.Started by Guest_Pilargalizia_* , 02 Jul 2026 |
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , 18 Jun 2026 |
