Distillation Column
heavy keylight key distillation mtbe methanol isobutylene
#1 Budiman arsen
Budiman arsen
Posted 07 July 2022 - 09:54 PM
I have a question related to the distillation column. why in the mtbe/methanol distillation column, in the bottom product there is mtbe? while the boiling point of mtbe is smaller than that of methanol
As far as I know, the separation in the distillation column based on a small boiling point will be the top product, while the high boiling point will be the bottom product.
Thanks you.
#2 latexman
  • 1,904 posts
Posted 07 July 2022 - 10:07 PM
Azeotrope?
https://www.academia...thylethyl_Ether
#3 breizh
  • 6,984 posts
Posted 07 July 2022 - 10:31 PM
Consider the template underneath
Azeotrope.info
membrane is a good option for this separation , use your favorite search engine.
note : attached a resource on Separation
 https://escholarship...96n0xv#page-489
#4 Bobby Strain
Posted 07 July 2022 - 11:09 PM
Your academic studies will eventually cover azeotropes. And, there is much more that you will learn. Be patient. And not too inquisitive at this stage. Concentrate on your studies.
