Calculation Of Heat Exchanger Tube Velocity
7 replies to this topic
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 10 August 2022 - 03:31 AM
Dear Sir,
How do we calculate Tube Velocity in Heat Exchanger ?
Please advice the formula ?
Q=UADelta T lm , can we equate this to V/A: Velocity is V and Area is A
  • 6,837 posts
Posted 10 August 2022 - 04:10 AM
Wow !
Did you check what is written in your post ?
On one hand there is an equation which  is related to heat duty of the HX ( KW)  and on the other end  Qv = V*Section  (m3/s)
Share with us your background and your role within your organization for us to support you effectively .
I'm really confused with your chemical engineering expertise and every day questions .
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 10 August 2022 - 04:50 AM
Dear Sir,
I am new to Process Design and I am from Refinery operational background wherein I monitor unit operations on daily basis only.
I want to know how to calculate Tube velocity ? What is the formula to be used ?
#4 breizh
  • 6,837 posts
Posted 10 August 2022 - 05:04 AM
The velocity in the tubes is the total flow rate divided by (the number of tubes * cross section of each tube) .
Let you study in depth the documents supplied , probably good for you to get a degree from Uni . Nothing wrong with your background but there is a long way to go.
Nowadays a lot of resources are available using google search or equivalent engine , same for videos using Youtube channel .
Good luck anyway
#5 fallah
  • 5,025 posts
Posted 10 August 2022 - 05:07 AM
No you cannot;
In a rough estimation, you can divide the volumetric flow rate passing through the tube side by the total cross sectional area of the tube side to find the tube side velocity.
#6 latexman
  • 1,856 posts
Posted 10 August 2022 - 06:29 AM
Dear CHEMSTRONG,
Are you a ChE degree holder?  I suspect not.  IMHO, this question can be answered by most Freshman or Sophomore ChE students and by some high school students and graduates.  It's like you ask a question that pops into your head with no real thought, not opening a reference, or any study or work at all.  Please research your questions thoroughly before asking.
We have jobs!  Stop wasting our time.
#7 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 10 August 2022 - 08:29 AM
Dear Sir,
I am really sorry. I am fresh professional Refinery Operations background .
#8 breizh
  • 6,837 posts
Posted 11 August 2022 - 11:02 PM
Search Online Courses, Lecture Videos, Video tutorials (freevideolectures.com)
This may help you .
