Depressurization Systems
9 replies to this topic
#1 VIrendra20911
VIrendra20911
  • 16 posts
Posted 02 November 2022 - 04:19 PM
In a pipe line of 1.5 kms and 6 inch diameter , 95% of ethylene and 5% nitrogen by volume are there.
Now according to process Requirement these 5 vol% nitrogen has to be removed from a pipeline by pressurization and depressurization technique.
We are pressurize this pipeline by ethylene upto 8 barg and depressurize upto 0.5 barg. So how much time it will need to reduce N2 concentration upto 0.5 vol%.
I need theoretical formula and guidance for this.
#2 Bobby Strain
Posted 02 November 2022 - 04:45 PM
Pipelines are usually purged to remove undesired material. Pipeline scrapers make the purging more efficient.
#3 latexman
  • 1,894 posts
Posted 02 November 2022 - 05:56 PM
I think guidance from NFPA 69 on "Explosion Prevention Systems" would be relevant.
#4 shvet1
shvet1
  • 476 posts
Posted 02 November 2022 - 11:59 PM
https://law.resource...urging.2001.pdf
https://santa.com.tr...-Explosions.pdf
https://www.boconlin...410-166975.pdf
Formulas above relate to vessels and short pipes where introduced and displaced gases can be mixed together more or less. Note for long or/and stagnant branched pipes methods other than pressure swing (e.g. vacuum swing, gas slug or pig) might become more cost or/and time effective.
Edited by shvet1, 03 November 2022 - 12:33 AM.
#5 breizh
  • 6,940 posts
Posted 03 November 2022 - 02:05 AM
Consider reading the document attached, you should find what you are looking for.
#6 VIrendra20911
VIrendra20911
  • 16 posts
Posted 03 November 2022 - 06:54 PM
Thank you all for showing interest and I respected your answers.
Mostly I go through the all pdf which has given but still I can't get proper equations for my question.
In one pdf I found it for oxygen displacement but it has written that this is only applicable for oxygen displacement.
So guide me more on this.
#7 breizh
  • 6,940 posts
Posted 03 November 2022 - 07:10 PM
The only way to get a right answer is to perform analysis at the outlet of the pipe, continuous monitoring or regular sampling.
Check with your lab what kind of support you can get or ask a third party (contractor).
Consider the new documents attached to get an estimate
notes:
*If the contaminant is N2 instead of O2 it should not be difficult.
**K = 0.25 for pipe, this means a safety factor of 4 to take into account the non-homogeneity.
Good luck,
#8 shvet1
shvet1
  • 476 posts
Posted 06 November 2022 - 11:09 PM
CEN/TR 15281 annex B can be applied to any gases pair if you apply appropriate constants as formulas stipulated are for general gas services. Just use k for ethylene instead of an inert gas. In your case safety factor is the only issue as you apply formulas for a vessels to a long pipe where good mixing conditions can not be reached and controlled.
Edited by shvet1, 07 November 2022 - 10:45 PM.
#9 breizh
  • 6,940 posts
Posted 07 November 2022 - 01:04 AM
The doc referenced above,
#10 Nikolay_
Nikolay_
  • 169 posts
Posted 11 November 2022 - 02:49 AM
Temperature and mass flow of ethylene? What time did you calculate?
