Air Separation Column
Posted 29 December 2023 - 02:14 AM
I'm currently operating 2 ASU which have output of 400 and 300 M3/HR of nitrogen gas which I'm venting out.
MY question is can I compress my nitrogen gas and use my unutilised column to produce liquid nitrogen?
Posted 29 December 2023 - 08:19 AM
Design the proper column you need for the service. Then see if your spare equipment would be suitable. Make adjustments to the process design if needed to find out how much capacity you would lose by reusing the spare equipment. Then perform the economic analysis for a new column versus using spare column.
Posted 30 December 2023 - 10:45 AM
Posted 30 December 2023 - 01:44 PM
It sounds like you will have to pay for the answer. I recommend you contract with a reputable engineering company/consultant to guide you.
Posted 01 January 2024 - 10:54 PM
You do not need a column to produce LIN from GAN
Posted 12 January 2024 - 06:22 AM
How come? Wouldn't the gaseous nitrogen need to be cooled to become liquid
Posted 13 January 2024 - 08:25 AM
[quote name="shvet1" post="130914" timestamp="1704168246"]
A plate and fin heat exchanger with cooling media (may use JT valve to bring temperature down of relatively a hot stream to use as a cooling medium for Gaseous nitrogen. Latent heat of condensation of nitrogen is much higher that specific heat)
Posted 14 January 2024 - 10:45 PM
GAN shall be cooled and/or pressurized to obtain LIN. Column does neither.
Posted 15 January 2024 - 10:12 AM
[quote name="rajibctg" post="131003" timestamp="1705059154"]
How come? Wouldn't the gaseous nitrogen need to be cooled to become liquid[/quote]
GAN shall be cooled and/or pressurized to obtain LIN. Column does neither.[/quote]
If the GAN is compressed and expanded to cool it, wouldn't it be done inside the column
#10
Posted 15 January 2024 - 11:41 PM
No, it would not.
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
Distillation Column Decommissioning ChecklistStarted by Guest_m.bhut_* , 08 Apr 2024 |
Separation Of Ethyl Acetate And IpaStarted by Guest_Jaiganesh_* , 14 Apr 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
Diameters Of A Structured Packing Distillation Column With No VapourStarted by Guest_hysyshunter_* , 07 Mar 2024 |
